Stacking, Ganging, Combining TV Antennas - Page 56 - Canadian TV, Computing and Home Theatre Forums
Old 2012-04-30, 12:43 AM   #826
roger1818
It depends how strong, but it should be fine. The thing about Yagies is from the side the reflector and directors don't have any affect, so it behaves like a folded dipole would from that angle.
roger1818 is offline
Old 2012-05-15, 09:36 AM   #827
takeaim
is it possible to amplify one antenna and then combine it with a 2nd antenna?
i'm looking to amp an antenna towards buffalo and then combine with an antenna towards toronto. or should i just combine the antennas and then amp that combined signal because amping just one will cause issues as far as phase etc?
thanks
takeaim is offline
Old 2012-05-15, 11:51 AM   #828
roger1818
^^^In general this is a bad idea. The antenna you have pointed towards Buffalo will also receive signals from Toronto at a reduced level. The amplifier will likely boost these signals enough to interfere with the un-amplified signals from the other antenna.
Old 2012-05-15, 12:02 PM   #829
takeaim
ok, so best to just combine the antennas and then add the pre-amp at that point and thus boost both, right?
thanks
takeaim is offline
Old 2012-05-15, 01:51 PM   #830
roger1818
Yes, that would be better, though not without its own disadvantages.
Old 2012-06-03, 06:29 PM   #831
totallyr
Default Spacing between Antennas?
Hi all, i'm planning on placing two 91XG OTA antennas on a dormer on my roof, the dormer is a fair size. One antenna will be used for my living room the other for my bedroom, i was wondering how far apart i should space them from each other so there is no interference. Also i have an FM yagi that is a fair size, how far should it be away from the 91XG antennas, thanks.
totallyr is offline
Old 2012-06-04, 09:45 AM   #832
nbound-au
Why not use one 91XG and split/amplify?
nbound-au is offline
Old 2012-06-04, 11:33 AM   #833
totallyr
I would be splitting to 3 tv's then as 1 of the antennas will be going to 2 tv's
totallyr is offline
Old 2012-06-05, 04:21 AM   #834
nbound-au
Use a pre-amp or spltter amp if required. But you'll only be taking a 1.5dB hit vs two outlets, which isnt likely to be a problem (unless you have some borderline stations).
Old 2012-06-05, 11:04 AM   #835
roger1818
^^^Agreed. A pre-amp's primary job is to amplify the signal where the signal is strongest (at the antenna). After the pre-amp, splitter loss is irrelevant. You do need to choose your pre-amp wisely, as they are not a one size fits all (see the amplifier thread for details).
Old 2012-06-05, 02:54 PM   #836
Mark_OB1
Location: SW Michigan, http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda0093f11cf4
totallyr,
not only is there the expense of buying two antennas (and mounts!), but the time to install them both. Plus two separate coax feedlines. And two ground drops. That's a lot of overhead, especially unnecessary if both antennas are aimed the same.
Installing a preamp at just a single antenna will not only provide enough signal for you to divide it several times to distribute to multiple TVs (after you get the single coax into the house), but also overcome the loss of your cable run, which could be significant on the upper UHF channels.
Mark_OB1 is offline
Old 2012-06-05, 09:46 PM   #837
stampeder
Yep, this raises the point of why we typically stack or gang antennas, which is for specific gain or aim requirements.
In totallyr's case a single antenna should do just fine with the proper network of amplification (and attenuation as needed) and splits.
stampeder is offline
Old 2012-06-05, 10:32 PM   #838
totallyr
Thanks guys and i'm taking the advice on going with 1 antenna plus the preamp, now i have to figure out how to turn the rotor on the telivision that doesn't have the degrees led display and the remote. Other than that i'm all set, glad i came for advice, saved some money and a probable rooftop eyesore, lol.
totallyr is offline
Old 2012-06-06, 01:21 PM   #839
roger1818
^^^One option is to get an IR to RF extender (or an RF universal remote).
Old 2012-06-06, 02:08 PM   #840
totallyr
I have this Powermid transmitter and receiver from years ago, i'll give it a whirl
totallyr is offline
OTA Forum Sponsor
