I have a Starchoice DSR505, and have been using SageTV as a HTPC.
Is there any way to record the DSR505's HD channels using any of the Hauppauge cards (1600/1800) without any hardware modifications? The only way I can think of doing it is with component cables, but then that's not pure HD, and I'm not even sure if the Hauppauge cards use component cables. thanks |
Moved to the HTPC section of the forum. See the following link on recording HD, which also contains a link to the Hauppauge...
http://www.digitalhome.ca/forum/showthread.php?t=14099 Recording HD Search tips, etc in the link below: http://www.digitalhome.ca/forum/showthread.php?t=57741 Useful post for those new to the forum
Use the Hauppauge HD PVR. Connects to your PC via USB and records any component video source up to 1080i.
C. |
#4 | |
The benefit for you is that this device works very well with SageTV but you need a reasonalby fast CPU to play back the H.264 files that it produces. |
