cascading SW44 switch for 5+ tuners - Page 9 - Canadian TV, Computing and Home Theatre Forums
Old 2009-10-16, 07:20 AM   #121
dosborne
This is getting off topic...............
But, yes, to some extent. Personally, I expect them to be sales people, not technical, but as I said, if they don't know, they should not guess or make stuff up. They should refer the customer to someone that actually knows.
dosborne is offline
Old 2009-10-18, 03:28 PM   #122
jimmy1
Default approved switches
I have two bell receivers and want to add two more but have 6 outlets. I read in the forum that I can use two 4 x 4 switches and two 44 switches for a reliable connection.
Do the switches have to be Dish or can I use a brand such as the Microyal for the 44 and other brands for the 4 X 4
I called a retailer today and he told me that I had to use Two Dish 44as and two 44 switches with bell receivers. Not sure if he is telling the truth or trying to up sell.
jimmy1 is offline
Old 2009-10-18, 03:54 PM   #123
Pinza
Bell use VideoPath SW44's and Eagle aspen for 4 way and 8 way single sat switch's.
I have used Microroyals in the past and they work just fine.
SW44a's are not approved or officially supported by Bell but again, work fine.
I think you mean 2 x 4 way switch's and 2 x SW44's.
Pinza is online now
Old 2009-10-18, 05:00 PM   #124
ScaryBob
It's cheaper to use four 2 way splitters (dish style with DC blocking on 1 leg/DC pass on the other) and two SW44s. One SW44a and one SW44 is also cost effective unless the SW44s are surplus/cheap or on hand. Other brands are Ok, as long as they are Dish/Bell compatible. Diseqc, Shaw, DirecTV, etc switches will not work with Bell receivers.
ScaryBob is offline
Old 2009-10-18, 05:04 PM   #125
Pinza
Splitters MUST pass 2 Ghz or higher.
Pinza is online now
Old 2009-10-18, 05:26 PM   #126
jimmy1
Thanks guys I had a feeling the guy was just selling me more than I needed.
I will try this set-up as described in the forum using the method as described in the forum.
{unnecessary image removed}
I happen to have one eagle aspen 3 x 4 multi switch.
I will get two Microyal SW44 Automatic Multi-Dish Switch
Please lwt me know if i can improve on anything.
Last edited by dosborne; 2009-10-19 at 07:25 AM. Reason: Removed duplicate images and merged into proper thread
jimmy1 is offline
Old 2009-10-21, 10:54 PM   #127
manuelj43
Sadly they just do not understand how to cable for more than 4 Tuners, at most Bell World & The Source Stores I come across.
Funny; even through sky dish, when i call in to activate a customer, I had a rep argue with me to install the power insterter on a multiswitch, And that the multiswitch that I installed was a sw-44.
manuelj43 is offline
Old 2009-11-01, 10:22 AM   #128
sctlenz
Default Difference between Switches
What is the difference between a 44a and just a 44?
sctlenz is offline
Old 2009-11-01, 10:29 AM   #129
Pinza
Firstly an SW44A is NOT an approved or officially supported Switch for use on Bell TV.
The SW44, has 4 inputs from the LNBF's, and 4 outputs to feed 4 Tuners.
The SW44A, has 4 inputs from the LNBF's, 4 outputs to feed 4 Tuners and 4 outputs to feed an SW44, if required.
Pinza is online now
Old 2009-11-09, 12:01 AM   #130
Quivox
Is there such a thing as a SW22? I went to a bell store today and that's what he advised, but I haven't seen that switch mentioned here. Right now I have dual Lnb's connected to an SW44, and I'm running 2 pvr's, but I want to add a third PVR as well as 1 line for a non pvr box.
Quivox is offline
Old 2009-11-09, 09:48 AM   #131
ScaryBob
Never heard of an SW22. He probably meant SW21. SW21s will support, at most, two receivers. For 3 or more receivers, one or more SW44s are required. There are oddball configurations using SW24s combined with SW21s or commercial options but SW44s are the best solution for residential use.
ScaryBob is offline
Old 2009-11-09, 12:50 PM   #132
dm_4u
However I have an SW44a switch working in tandem with an SW44 switch...without any issues...to power the following receivers: 9242, 9200, 6100 and two 3100's.
On the other hand I did all the install work myself...and I'm no professional installer...
(Pinza...in fact I wish you were selling those switches on a board, two months ago...in fact I still almost bought #1...except shipping would probably be an issue).
All I'm saying is that it may not be officially supported by Bell-TV...but it does work.
dm_4u is offline
Old 2009-11-09, 07:07 PM   #133
Quivox
Thanks for the answer! My set-up right now is 2 Lnb's connected to an SW44 switch, which are then run to 2 dual tuner receivers( 9242 and 9241) I want to add another 9241 as well as a 6141 and a 6100.
The satellite guy I talked to today said the best solution is to add 2 3X4 ZINWELL SAM - 3402's and another sw44.
which is similar to the 2nd option in this thread. Will this work? Are Zinwell products rated highly? He said he would supply the SW44, the 2 3x4 switches and the cabling for $200.00.
Quivox is offline
Old 2009-11-09, 11:15 PM   #134
ScaryBob
Thumbs down
That's a bit expensive. An SW44 is worth at most $100 new or about $35, including shipping, on eBay. (Forget what Bell charges, nobody else wants that much.) 4 Dish compatible splitters can be used for about $5 each or two off-brand SW24s can be used for $15 each. The cables can be purchased or made for about $2-$3 each. For $200, he should be installing it too.
ScaryBob is offline
Old 2009-11-10, 12:15 PM   #135
rosenqui
On the other hand, wiring-wise, the simplest thing would be for you to just get a SW44A and put that in front of your existing SW44. Not "officially" Bell supported, but works well for many other users.
Last edited by dosborne; 2009-11-10 at 12:57 PM. Reason: Portions deleted. Please read the forum rules re buying/selling
rosenqui is offline
Tags
cascade, cascading, sw44, trunking
