has anyone ever heard or i guess, seen this before??? i have moved all my stereo equipment away from the tv, but it is still there. how far should you keep stereo / speakers away from these flat screen tvs??? is there anything you can put in between the tv and a speaker, so that you can put it closer, without distorting the screen??? thanks. ps. cool forum. i just joined. i found it thru kusat. i like this one better, sorry kusat. |
Secret trick - try turning the TV on and off in fairly rapid succession about 10 times or so.
If that doesn't work, you'll probably need to get it professional degaussed. |
Johnny can answer better sounds like your speakers aren't properly shielded so the magnet in the speaker is screwing up your tv.
If I've got the terminology right you need to deGauss (demagnetize) your screen. Don't know how on your set, try reading the manual or maybe somone else out there can help! p.s. thanks for the kind words and welcome to the forum |
he took it apart and applied a magnet on the tube. he moved it around until the spot disappeared. does this sound right??? have you ever heard of anything like this before??? it did fix it though. he said that they have trouble with the flat screen monitors when it comes to magnetism. if you have a pot light that is close to the screen or an unshielded wire in the wall behind the tv, it could cause this problem. i have also noticed that, i have a bryston 4b beside the tv, and if i move it too close, it screws up the screen. are these tv's all like this, or do i have a lemon??? thanks. |
What the technician did was use a degaussing coil to de-magnetise the shadow mask and yoke of the TV.
All direct-view TVs are susceptible to this. |
if you are talking about a round thing that plugs into wall, it was not that. the magnet was applied to the tube and left there.
is that what you meant??? |
Nope, I was talking about the round thing. I have no idea what he might have left inside your set, but I am curious!
My TV is "popping" and turning the picture green. It then shuts itself off. The only way to recover is to unplug for 20 secs and the plug in. The picture is green at this point and then bursts to normal colors fading from dark to normal in a matter of 5 - 6 secs. This shutting down occurs 5 to 10 times in the first hour of use. Then sporadically over the course of on time.
