#211 |
Thanks so much, now I can order my HVR-1600 without WAF problem.
#212 |
Anyone tried the Sapphire Theatrix 650 that comes with software and remote ??
LG55LW5000/Denon3313/MirageOMD5+Nanosat+MM8/ClearStream2/CM7778+3414 SSGPN50A550/OptomaHD33/Onkyo717/KEF3005/Velo15" |
#213 |
I used a Sapphire 550 for two years and was very satisfied. The 650 adds ATSC support I believe, so I can't comment on that since it's new, but playback and capture in NTSC was flawless.
Mine came bundled with BTV 3.5 which is excellent software, but no remote. I finally went with a Hauppauge 1800 to replace the 550 this year, since I wanted something on PCI-E, with ATSC support.. |
#214 |
Thanks for the reply.
I want to know if the software in the 'retail' Sapphire Theatrix 650 comes with a TV application that supports EPG and closed captioning. They are not putting ATI MMC on the box so I doubt if they are coming with the ATI software like the Visiontek etc. I certainly won't mind if BTV is included and wound support the above functions for ATSC tuning.
#215 |
I e-mailed Hauppauge today about the new HD-PVR, and was told that they've "slipped" on their release date, now looking at a late april-may release.
I may be having second thoughts about an HTPC, slightly. The HD-PVR would really make things so much easier for me and my setup. Anyway, just thought I'd give everyone an update. |
#216 |
I just bought a Avermedia Combo PCI White box dual tuner card from newegg for $89.99 plus shipping. The card works great has 1 NTSC tuner and 1 ATSC/QAM tuner. ATSC tuner has great sensitivity I get more HDTV channels on it than either of my TV's, HDTV wonder or Technisat AirStar HD-5000. I am currently just using the Avermedia software that came with it on Windows XP and plan to upgrade that pc to Vista to try that out. The other two cards run on Myth.
Links to the card: http://www.aver.com/mpd/combopcie.html |
#217 |
I am unable to find software that will create a DVD that I can watch on an ordinary DVD player.
The last software I tried was "ImTOO MPEG to DVD Converter" but it strangely converts files that was transmitted in HD but were originally re-transmission of SD ok, as I get video and audio stream to the DVD player but those recorded of HD source without the video and only the audio on the player. Do you know what conversion software works. I just split the signal going into that first feeds a VCR..so I can record on VCR directly with SD NTSC Stuart P4 ATI AIW9600 has NTSC tuner |
#218 |
ConvertXtoDVD
#219 |
Towerpower, see my reply in your other similar post.
SA8300HD; Panasonic TH-50PZ850; Sony STR-DA5ES; Tannoy: Arden, S8C, S8LR; SVS 16-46PC+; Oppo 971; Harmony 659/680 |
#220 |
Just a quick question. My plan is to use Vista to watch TV from my Starchoice reciever, and eventually get the HD PVR when it comes out. For the time being will any cheap tuner work? And do I need a NTSC or a ATSC if it is coming out of the starchoice reciever?
Thanks! |
#221 |
For the SC receiver, just NTSC (with A/V inputs). You may want to get an ATSC/NTSC card though, or separate ATSC/NTSC tuner cards, givien your prime location for ATSC.
#222 |
Hey guys, I'll soon be looking into building an HTPC and I'm trying to get all the plans done now.
Right now, I currently have Bell ExpressVu Satellite, and I'll be looking to upgrade to HDTV. So my plan is to hook up Bell's HDTV Recevier to my HTPC, problem is I can't seem to find any TV Tuner cards that actually have any HD input, most of them only support Free Over-The-Air HDTV or QAM. So my question is, are there any TV Tuner cards that have any HD Input (HDMI, Composite, DVI?) inputs so that I can do this? And if so, what card would you recommend? Thanks. |
#223 |
Premium Supporter
Hi!
This (http://www.hauppauge.com/site/products/data_hd_pvr.html) has component input... It's not out yet though, it will apparently be available May 1st... Have a nice day! Nick |
#224 |
Thanks Nick! I probably won't be building until mid/late May, so that would be perfect!
But just for comparison purposes, are there any other HD Tuner cards out there or any other [non-illegal] methodes of receiving an HD Satellite signal with an HTPC? Thanks again! |
#225 |
The only other method is the 169time where they alter a satellite box to give it a firewire output. But the Hauppauge method should be much more supported by software, at least by Sage and BeyondTV.
