#1 | ||
I've called and e-mailed many times regarding these issues - both Rogers and TMN (Astral). I have finally received a response from Astral - from someone who appears to know what he's talking about. Here is his response to my e-mail regarding the issues in the "subject line"
I'd really appreciate it if anyone could verify the items I discussed in my points 1 and 2 regarding the range only affecting analogue audio and not digital, also perhaps the amount of dB effect. Thanks in advance.
Impressive email 57....
I tried "The Others" last night for a few minutes and found (as with some of the other movies) that the analog sound was low and the digital sound was so low it couldn't be amplified correctly no matter how loud the volume was turned up. What I don't understand is that this is not a "Channel" sound problem as this ABC HD, but a "Movie" problem.....the Sopranos always has the sound level correct. Therefore his assessment of the problem todate isn't necessarily so. Its interesting that Astral seems to have taken the lead on this problem...not Rogers... |
#3 | |
#4 | |
Great stuff!
#5 | |
ie 90 dB at 1 Watt (typical speaker) would produce 93dB at 2 Watts and 100 dB at 10 Watts and 110 dB at 100 Watts.
Here is Astral's response to the points I brought up yesterday. (I got the response first thing this morning after sending it last night). I guess once you're in touch with the "right people" things happen. The "red" are Astral's answers to my questions.
1. I tried changing the audio range on my SA3100HD STB several times and there were no changes to audio levels (using the digital out of the SA3100HD.) The audio range setting only affects the analog stereo output of the set top.* It is used by the Dolby decoder in the set top to set the audio gain.* With the digital output a compressed Dolby digital signal is sent to your receiver and your receiver does the decode according the factory default (or modified if your receiver lets you get in a play with the Dolby decoding parameters).* You are correct though, with the digital out, the audio range setting will not affect the audio level on your receiver/amp system (again it only affects the analog out of the set top). 2. When I changed the setting on my Yamaha RX-V1 receiver to "analogue" from digital I did notice that there was a change. I took out my trusty sound level meter and would estimate the changes at about 3dB for each shift from Narrow to Normal to Wide, not 11dB as you mentioned. 22 dB is a HUGE amount and my dB meter would have no problem detecting such a massive shift, it was closer to 5-6 dB for the full shift from Wide to Narrow. I have not done detailed measurements myself.* These numbers come from a Dolby/Scientific Atlanta bulletin.* However, in listening to the changes, in wide mode the audio becomes almost inaudible on most programming, which indicates a pretty large shift. 3. This however, does not solve the problem, as I mentioned earlier, I want to use the digital out, not the analogue out to be able to take advantage of the clearer dolby digital signal and to properly decode DD5.1. I don't want to listen to a digital station in analogue audio. Perhaps this is a problem related to the SA3100HD only (or perhaps only my 3100HD), but a 3dB change is not going to take care of the massive 30db differences I've seen anyway... The movie that is the "worst" for this audio problem is "The Others". This movie is approximately 30dB (yes that much) lower than the others, in the dialogue. As I mentioned in my original e-mail, it almost seems as though your "digitizer" has missed theentire centre channel material and that the only audio picked up is what is contained in the LF & RF channels. Just to re-iterate what I was saying yesterday...you are not doing anything wrong (though I strongly recommend you use audio range narrow for any analog output use). The problem is at our end in the digitization process.* We don't have enough audio gain in the system and I will get that fixed.* One of the movies I looked at is "The Others" and I agree that the level is at least 25db lower that it should be. 4. I have one more quick question. How do the movies get to Rogers? Do you send a "signal" or is there actually a "tape" sent to their Head End? You mentioned a video file server, so I would assume that you are sending a signal. Please confirm. The movies are on a digital video tape format (called D5 if you are aware of professional tape formats).* The video tape is played into an MPEGencoding system for storage on the video file server (this is the digitization process).* I fully expect this problem will be fixed simply by boosting thegain at the output of the video tape deck.* I have the operations people who do this work checking that today.* I will let you know when I think we have it fixed and may ask you to let me know if things have improved.* Again I really appreciate your expert feedback.
I'm lost.... so does this mean that there will be DD5.1 sound on the HD TMN and PPV channels soon? Also, who is the other company broadcasting DD5.1?
#8 | |
2. HDABC, HDPBS, BEV (HD).
#9 |
I forgot to add OAR presentation of films, instead of butchering and chopping???
#10 |
???? OAR is one of the issues on the table...
#11 |
57, I think the Video File Server is at Rogers....
#12 | |
Aaaah, you could be right (human says the same). It's just that the "we" in the last sentence below taken from his response makes it sound like Astral, not Rogers....
#13 |
A quick note...
The audio on the DVD of the The Others was also *very* low. Maybe this problem is specific to this movie's audio mix. Later. |
#14 |
Its strange that the HD PPV movies don't seem to have any sound problems....they come from Astral as well. I wonder if its the same process....sneaker net from Astral to Rogers then loading the material onto the Rogers server. In fact, I wonder if all the Astral products make there way over to Rogers by hand????
#15 |
According to Sound & Vision's Glossary, a dB is:
"A logarithmic unit expressing the ratio of two powers, currents, voltages, or sound-pressure levels (SPLs). An increase of 10 dB represents a tenfold increase in power, and an increase of 20 dB represents a tenfold increase in voltage. Doubling the power in watts delivered to a speaker raises it's output SPL by about 3dB." And for sensitivity: A speaker that is 3 dB more sensitive than another requires only half the amplifier power to deliver the same playback volume. I'm still confused |
