#76 |
jgvp
you are starting to look more and more like a troll than someone who is just asking legitimite questions. |
#77 | |
Panasonic PT47X54 Motorola DCT-6412 |
#78 | |
#79 | |
#80 |
Has anyone else experienced unreliable timer recording through their 6412? A few times this week, there have been shows for which I had timers set, but they failed to record. I'd like to know if it's a problem isolated to my box, or if it's a widespread problem.
#81 | |
I was having a few issues with my 6208, so it isn't that I simply waltzed in with a 100% functioning unit and asked for a free upgrade. It appears that Cogeco felt that it was a better choice to replace the unit than trying to repair it. |
#82 | |
#83 |
Anyone have issues connecting your pc with firewire to your 6412??
I am using this as a guide: http://www.avsforum.com/avs-vb/showt...0&pagenumber=1 I installed the Tuner AV/C Device as explained there, tried rebooting,etc,etc but, when I run CaptureDVHS it doesn't show it as a capture device listed. EDIT: - OK Ignore my message.. but, I will leave this here in case someone else has the same problem! I guess I read the instructions too quickly. I didn't realize for any device you need to select the panasonic dVHS. I let windows autoselect the driver and that is what messed me up! So, it works fine now Last edited by ylsf; 2005-03-19 at 01:39 PM. |
#84 |
I have traded my old (purchased) dct for the latest model, the 6412.
No charge at Cogeco Pen centre, St. Catharines. Very happy with improved PQ, guide etc. I connect it to my TV via DVI. Waiting for dual tuner activation this fall!! I am experimenting with the firewire output. I plugged it from the 6412 into my Samsung SR T165, which in turn is connected to my JVC HM DH4000U recorder via firewire and to myTV, A Sony KE-42TS2U, via DVI. Picture and sound are getting through. I was hoping to be able to record some programs, those i may want to keep or lend to friends on the JVC. The JVC and the STB work fine together to record programs off air and playback. the firewire program on the STB allows for setting recording times etc. But I can't figure out a way to record and playback anything from the cablebox. Perhaps there is a firewire input on the cable box., but there seems to be no way to choose input sources. I would also like to use the inputs on the front of the 6412 to play back from my digital camera. There is a button at the bottom left of the 6412 remote marked "video source". It doesn't seem to do anything. So my questions are: Has anyone been able to activate this button, or any other method of using the front of the box video/audio inputs? Anyone have any other ideas on how I can record HDTV from the 6412 and playback? I would appreciate any advice. I'M going away for a few days so will respond later to any further questions, Many thanks |
#85 |
We just got this box and I noticed the apartment building's lobby security camera is gone. It was on channel 69 with our previous digital cable box (cogeco), but on the 6412 it's not there. It doesn't make sense. I have searched every channel, channel by channel on the box but its not there. How can it be on our other previous digital box on channel 69 and not on the 6412. I phoned Cogeco, but the guy gave me a song and dance about it being a problem in the building. This is bull because 5min before I unhooked the old digital box to hook up the 6412, I used the lobby cam on the old box to let my buddy in the builiding. Can anyone help please? I love the DVR but the lobby cam is something we can't do without. There must be a way to get the lobby cam on the 6412 if we can get it on a standard digital cable box.
#86 | ||
All opinions expressed are my own. |
#87 |
Yes, there is no 969, when I try 969 it just goes back to the channel were currently watching. We are in Kingston, Ontario
#88 |
Since Kingston is not all digital that's why 969 doesn't work.
I would check the other channels up there. Its usually odd to sub over the Legislature Channel. Usually they'll go over TVA, or the Shopping Channel, try 68 and see if the lobby camera shows up. |
#89 |
I recorded "Tout le monde en parle" on Tv5 last night here in the Oakville area. Well, today when I am playing it back the Fast Forward isn't working correctly. The first FF seems to move like normal but the FF2-FF4 are VERY slow (Seems slower than FF1).
Any suggestions or tips? Could it be an issue with my box or that channel in particular? This program is 2 + hrs and I need to find something near the end! Anyway.. I guess I will try record some other programs and see what happens once I am done finding what I am looking for on this one. EDIT: - After removing power from the uniting for 5 minutes and re-connecting the FF/Reverse worked again. I guess that is why they say to remove the power first before calling tech support Last edited by ylsf; 2005-04-14 at 01:40 PM. |
#90 |
I am presuming that the 6208 thread is dead, given the date of the last posting. My rental unit crashed yesterday and I am now expecting a replacement 6412 next week. My question is whether anyone knows how I can access the hard drive on the 6208 and dump the contents (2 seasons of Six Feet Under) onto a VCR or other storage device? I don't know what Cogeco is doing with all of the working 6208's being traded in but I wd love to get my hands on one for a day or so so I could swap the hard drives and rescue my shows. Comments anyone??
