Such a thing as a GH/Yagi Hybrid? - Canadian TV, Computing and Home Theatre Forums
Old 2012-07-05, 04:46 PM   #1
darexl
Question Such a thing as a GH/Yagi Hybrid?
A question out of topic a bit.
Do you know if anybody experimented with GH-Yagi hybrid antenna?
I mean somethin like Yagi in mounting but with all directors and reflector built as classic GH (or possibly as ZZ4)?
darexl is offline
Old 2012-07-05, 05:56 PM   #2
ota_canuck
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
Do you mean something like this but with a GH/SSH instead of the dipole?
3D SSH III with ZZ4 refl. http://imageshack.us/user/jmsdigital
ota_canuck is online now
Old 2012-07-06, 10:56 PM   #3
300ohm
I've played around with directors for the GH. (that's how I discovered the NAROD, heh) It seems like the best directors for the GH is another GH element, and you need like 5 to make a noticeable difference in gain. This of course makes the build fairly difficult and pricey.
300ohm is offline
Old 2012-07-08, 09:13 PM   #4
darexl
Thanks for quick answer guys.
Yes, something like that. I tried to build it with 3 GH elements (classic 7") but of course with 3, my reception did not improve much. Yes, it is a lot of work and it is difficult to keep consistent in construction. I used 2.5" spacing between elements and 5" from active element to reflector (aiming for real channel 23 - ION is a bit elusive in Hamilton area).
In spite of construction, size and cost issues, I wonder if there is a potential here?
darexl is offline
Old 2012-07-08, 11:11 PM   #5
Damon Hill
Here's a Yagi design that kind of suggests what you're thinking of:
http://ronsmithaerials.com/catalogue/menu.html
Also, a "grid Yagi" sounds similar:
http://home.comcast.net/~ross_anderson/GridYagi.htm
Though both would have terrible wind and ice loading!
--Damon, who is having a terrible time finding SMA connectors and cables locally so he can finish a quad curtain antenna
Damon Hill is offline
Old 2012-07-09, 04:59 PM   #6
darexl
Thanks,
I am allowed to play with attic only so environment is not an issue
Mounting of 10 or more GH elements 2.5" apart on the other hand could cause a bit of a challenge
darexl is offline
Old 2012-08-04, 08:36 PM   #7
zdcyclops
Question Great minds think a like
I had sort of the same idea except to make the antenna bi- directional with UHF on the front side and VHF on the rear with its own down lead and an AB switch to pick which side you used. Is this workable or would a set of elements behind the reflector/directors fudge the gain on the front side?
zdcyclops is offline
Old 2012-08-04, 11:04 PM   #8
300ohm
Actually, you can do that now WITHOUT the A-B switch with the original GH with straight NARODs for a range of about 3 vhf-hi channels.
http://www.digitalhome.ca/forum/showthread.php?t=99907
Notice the channel 7 and 8 gain is stronger on the backside for the 28" straight NAROD.
UHF gain from the front and VHF-hi gain from the rear could be further optimized on it, but there hasn't really been any demand for it.
300ohm is offline
OTA Forum Sponsor
