Running Speaker Wires - Canadian TV, Computing and Home Theatre Forums
Old 2012-06-28, 12:50 PM   #1
Raiders_8180
Default Running Speaker Wires
I ran 1 speaker wire from inside my house to outside last fall.
Drywalled, plastered and painted everything. I'm just getting around to designing a deck and have realized that I ran 1 speaker wire to the outside rather than 2. I was in a rush when I drywalled and wasn't thinking about outdoor speakers at the time.
Is there anything I can do so I can have 2 outdoor speakers with only 1 wire?
Or
Can I use the existing wire to try to run another?
Raiders_8180 is offline
Old 2012-06-28, 02:07 PM   #2
takeaim
use that one wire to fish 2 different wires through? if you get lucky and don't have any snags it could work. tape 2 wires to that one wire very well and pull.
takeaim is online now
Old 2012-06-28, 02:54 PM   #3
audacity
Yeah, do what takeaim suggests... or if you're happy with mono sound you're all set up for that.
audacity is offline
Old 2012-06-28, 03:11 PM   #4
tandem
Hide behind baseboards? How much distance do you need to travel?
tandem is offline
Old 2012-07-02, 07:22 PM   #5
Raiders_8180
That was my plan, to use the existing wire to run 2 more. I was a little afraid that if I hit a snag I would end up with no wire.
That looks like the best solustion though.
Hiding behind baseboards wouldn't work for me.
Old 2012-07-11, 12:26 PM   #6
Raiders_8180
Tried pulling on the wire from either end and it won't budge.
Is wireless outdoor speakers an option or are they not very good?
