8300HD ER01 code - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Videotron
Old 2011-12-23, 01:10 PM   #1
bubbah16
Thumbs up 8300HD ER01 code
Videotron 8300HD with error code ER-01.
Is anyone familiar with it?
Could a new drive fix that or is it simply a motherboard failure issue?
Any input would be appreciated.
Enjoy the holidays
bubbah16 is offline
Old 2011-12-23, 03:47 PM   #2
nitra
Unplug the box for at least 30 seconds, power it back on and see if the error clears.
I've seen it before, normally it will clear with a reboot.
nitra is offline
Old 2012-06-23, 09:58 AM   #3
3456
Location: GTA, Ontario (Rogers Cable), Sony rear projection, SA8300HD
I got the same Er01 on my box now. Full reboot from cold (ie unplugging) hasn't fixed it. Any pointer as to the cause or where can I get it looked at in the Toronto area? I own that box.
Thanks...
3456 is offline
Old 2012-07-11, 08:53 PM   #4
3456
I ended up bringing the unit to the CableShoppe in Toronto. It was a bad RAM module. The repair was $56.00 and took a few days
3456 is offline
