Windows Explorer will only display icons, not thumbnails - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Computing > Windows Computing
Old 2011-04-02, 07:05 PM   #1
Wayne
Default Windows Explorer will only display icons, not thumbnails
FYI - my OS in Win7 Home Premium. This problem pertains to folders that contian jpeg picture files.
For some reason a little while ago Windows Explorer stopped displaying thumbnails when using the display options of Extra Large Icons, Large Icons and Medium Icons - instead it just displays the Icons. What will happen is that the picture thumbnail will be visible for a brief instant before it is replaced with the thumbnail.
I have tried checking and unchecking the Always show icons, never thumbnails.
I have tried changing the default display program for jpegs. I have tried several options including Windows Photo Viewer, Windows Live Photo Gallery, Picasa Photo Viewer, Paint, etc.
All I get is a brief flash of the picture and then the icon takes over and the icon changes depending on which program is currently the default.
Note that I have no problem actually opening the picture in one of several programs, it is just that I cannot see thumbnails of photos in Windows Explorer - and this is a very good way to just browse your photo collection.
Anyone have a suggestion?
Wayne is offline
Old 2011-04-02, 09:14 PM   #2
nospam
I have heard of this happening when your hard drive is getting close to full. Try cleaning up your drive and emptying the Recycle Bin to see if that has any effect.
nospam is offline
Old 2011-04-03, 06:31 PM   #3
Wayne
I did have a lot of stuff in the recycle bin, I emptied it but that didn't change anything. I also have tons of free space on the drive a few hundred gigs.
Wayne is offline
Old 2011-04-03, 07:16 PM   #4
BGY11
Open Disk Cleanup, ensure "Thumbnails" is checked then run the cleanup. Sounds like the thumbnail cache is messed up.
BGY11 is offline
Old 2011-04-03, 08:00 PM   #5
mateo_f4
Thumbs up
In Windows Explorer, go to the "Tools" menu, select "Folder Options". On the "View" tab, "Advanced Settings" ensure that the first option "Always show icons, never thumbnails" is NOT checked.
mateo_f4 is offline
Old 2011-04-03, 09:06 PM   #6
BGY11
^Good idea! I wasn't at a Windows 7 desktop when I posted my reply, but that should be the first thing to check.
BGY11 is offline
Old 2011-04-03, 11:28 PM   #7
Wayne
You rule! That did the trick - I had unchecked the Always Show Icons option as I indicated in the original post.
Wayne is offline
