I was watching the FIFA confederation cup on CBC HD OTA and notice that Radio-Canada (SRC) was not showing the games in french. The were only offering the web stream. Since CBC offers other language beside english on its web stream like Panjabi for HNIC. Why don't they send multiple audio stream like french when its sister station is not broadcasting ? They could also increase their rating with some spanish during the world cup.
Thanks, |
#2 | |
OTA brings you crystal-clear, uncompressed HDTV, no simsubbing, and the real SuperBowl commercials. You can't get all that on satellite... OR CABLE. |
It is really how the receiver/ATSC/PSIP system can handle multiple Audio streams.
Ideally, you'd press an Audio button and gel a list of available audio feeds you can choose from, or get a different sub-channel number for the main audio plus different audio. According to my TV manual (Soyo), apart from the MTS/SAP button on the remote (which seems to be written in reference to analog TV), it is hard to tell how to select a different digital audio program. |
While the ATSC standard and equipment can do it, the budget for simultaneous translation services would be huge, and I would say goes against the CBC's mission statement let alone its funding.
Here's a business model that might be of interest to large ethnic groups in specific linquistic areas of Canada: (such as Punjabi in Surrey, BC, etc.) approach the authorities and the CBC for affiliate rights to broadcast the original CBC ATSC feed stripped of its audio streams, which are replaced with overdubbed, real-time translation into one or more languages. Since the original CBC station is still running in the market, simsubbing could also be allowed for local commercials in those specific languages. This frees up the CBC from having to make public policy decisions that might be considered against its mission statement and for which some Canadians may take exception. |
I'm not thinking of simultaneous translation, but rather picking up audio feeds from a foreign broadcaster. As long as the timing isn't more than a couple of seconds out, it should work for stuff like international soccer matches. A totally made up example... Greece versus Brazil; pick up a feed from a Brazilian radio station and a Greek radio station. There's bound to be one covering the game for each participant.
Or for sports games - forget translation.. surely they could afford to pay someone to be a commentator in french considering the extra viewers they'd gain.
I too was thinking of using an international feed instead of translating. Also, french commentary can be obtain from Radio-Canada at little to no cost.
I remember watching a confederation cup game were CBC struggled to get the english play by play commentary from South Africa . Most of the game had stadium noise only and CBC ended up using ESPN's audio around the 80th minutes. That probably cost them but also shows how easy it can be done. |
Am I the only one who gets a loud popping sound with certain Dolby Digital programs? It happens during commercials and end credits, mostly with NBC (channel 2.1) and occasionally CBC (5.1). It sounds horrendous. Channel strength is 100% and picture is perfect. I'm in NE Toronto.
I'm using the tuner in a Panasonic plasma (TH58PZ700), with optical out to a newer Denon receiver (AVR789). |
#9 |
I had some pops last night on 2.1 on my Samsung LCD, but I've never noticed any using my converter boxes, I have an Insignia and a Zenith (which are actually the exact same).
#10 |
I've heard this as programming changes from DD5.1 to DD2.0, however, it's usually on inexpensive HTiB systems and I wouldn't expect that from your Denon, although the source of the problem might be the TV output, or the original programming if you don't see, er hear it on other channels.
CBC always sends a DD5.1 signal, but most programmes are 2 channel (coming out the LF & RF only), while others are actually DD5.1.
#11 |
I often hear audio distortions that sound like a warbling static, especially (for some reason) on commercials and credit sequences (or that little two note Law and Order bit they play on the titles...)
CBC is especially bad, but it happens on other channels as well. I thought I was the only one! I have a 50" Panasonic Viera. Can't remember the model # offhand, sorry. I use an RCA antenna purchased at FutureShop (lousy, I know). |
#12 |
I've noticed this problem on occasion...very loud when it happens.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
#13 |
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
I've had the same audio problem, but usually only on Buffalo 7.1 WGRZ.
Periodically I hear a sharp snap and then the volume or tone changes slightly. It's more noticeable when I'm running the audio through my old but powerful Techniques stereo amplifier with the volume cranked and the bass boost turned on. It almost seemed like a static charge & then a discharge of static in the speakers. I thought it was just a problem with my audio set-up. |
#14 |
I am experiencing consistent audio "dropouts" on Sun TV (15-1) from my Samsung receiver's digital output to a Techniques audio receiver.
#15 |
Audio dropouts are usually related to low ATSC signal strength, when it is just barely above the threshold of digital lock, so I'm thinking that the problems discussed in this thread probably relate to the individual ATSC tuner's processing of the data streams.
