#46 |
I'm not sure if this is an issue or just me not being able to figure it out but here's my question. I have been setting up recording events for some of the US prime time shows that we watch. For example I did a search for Survior and set it to record New Episodes from HD channels only. When I checked the event I see that it is going to record the new episode and use GlobalHD channel 303. This is correct, but I would like to be able to specify the HD channel at the time I create the event so that I can record from the US feed which I believe would be CBSHD 322. I think it picked the GlobalHD channel because it is simply the first one on guide showing the show in HD. With no other input from me it simply picked the first channel that meets the criteria. Same thing happened when I setup The Mentalist. It picked CTV HD which again appears on the guide before the FoxHD channel. I worked around this by looking up the upcoming boadcast screen and unselecting the record icion on the Global channel and selecting the CBS channel. But that seems like more of a work around then it should be so I was wondering if there was a way to specify the channel when multiple HD channels show the same show at the same time. Sorry if this is obvious, but I can't seem to find a better way. Thanks
#47 |
^ Just be on the channel in which you want to record (ex 303). Then under PVR Options instead of picking SD or HD only, pick 303 only.
#48 | |
I agree with a previous post that said some of the problems are as a result of the hard drive not being able to keep up. I had this experience. While fast forwarding through a very long recording (7 hours of US Open tennis), after going through 1 or 2 hours the picture froze. Pressing PLAY worked. Another time I left the picture frozen for a while and the picture began fast forwarding again on its own but it jumped ahead 30 minutes or so. It appeared that the fast forwarding was continuing in the background but wasn't showing. Another issue that came up during watching this recording, and another long one, was that near the end of the long recording the skip forward function had a delay of one or two seconds each time. Fast forward was also slower and had more pixilation than near the beginning of the recording. I have no idea why this would be the case but I guess I will just avoid doing very long recordings in the future. |
#49 |
jcol
This is how I set up series recordings for future episodes for a certain channel,go into guide (future listings) pick your show and highlite it,(I did this with Parenthood,Grey's Anatomy and My Generation so far) then press the enter/ok button.From there you will go to program options screen,highlite and enter record new episodes and your series will record on this channel only. At least that is what my future record list is telling me for Parenthood because it goes 2 weeks out and will record on channel 320 NBC east HD for that show. |
#50 |
Just this afternoon, on all channels (SD and HD) I was getting frequent audio and video dropouts.
Soft reset- seems okay now. Connection: HDMI to Yamaha amp - HDMI to Sony TV.
Shaw Direct DVR630 / DVR 630/ 605, Panny VT55", Sony XBR4, Oppo 980H, Yamaha 7.1 Surround, PS3! WDLive |
#51 |
I have a real big problem that SD support seems unable to fix. I originally set up my 630 with the two coax lines hooked up and attempted to start. It all worked fine until I went to change the channel and the box locks up and needs to be reset. I reset the box and let it sit overnight and tried again, same problem. So I hooked up each coax line individually to the old receiver and both work fine. I have done factory resets and it still did not resolve the problem. Finally SD suggested hooking up the box with a single line, which I did and it works, I just do not have the ability to record and every time I change a channel it says "acquiring signal from satellite" every time. Anyone have some suggestions, as I have spent over 2 hours on the phone with SD and no one could help...
I have it hooked up directly to my TV through HDMI. |
#52 |
Just to be sure, have you just split one line into two? They do need to be dedicated lines.
#53 |
they are definitely dedicated lines.
#54 |
Ok. You need either a service call or a replacement 630.
#55 |
I had four corrupted recordings today ... not sure if the 630 rebooted ... they were NOT concurrent recordings and all occured at different times with a combo of HD and SD? They appear in the list with the same indicators as the 530 except they don't play at all.
Here we go again ... I can't believe I got sucked into this beta testing crap again ... how many years is it going to take to fix this piece of &(#@$^ ????? I am SOOOOO disapointed!!!!!!! Update: Tried soft reboot and still can't play these corrupt recordings. Update: At least they can be deleted! Last edited by osmosis; 2010-09-12 at 01:22 AM. Reason: Update |
#56 | |
#57 |
Hi, I can't get the option on my remote, I try with my Harmony and with my ShawD remote ?
Can someone help for ? Thanks again |
#58 |
Don't know about Harmony but the Shaw Direct remote is just press the "options" button (bottom right on the new black remote). Make sure the remote is in "SAT" mode.
EDIT: Not sure about the Harmony but the Shaw Direct remote just press the "MENU" button (the "A" button on the old silver remotes), move over to "PVR REC" press that icon, brings up a submenu which you will slide over to "Options REC" and make your adjustments for each show there. Highlight each show you want to change. Don't change pvr options from the main "options" button on the remote or the changes will happen to ALL programs which I found out was a real pain. Doing it for each show from the "MENU" button works alot better.
~Gary Shaw Direct 630 HD/PVR | WD My Book AV eHDD | Sharp Aquos 46" 120Hz LCD TV | Watch me LIVE! Last edited by GaryE; 2010-09-12 at 09:14 AM. Reason: Opps wrong "options" menu... |
#59 | |
#60 |
57, Should this not be a sticky??
There's been no activity for a day, and it's almost lost in the list. Also, this one has the risk of being used as the original owner's thread, with resulting confusion. I suggest: - questions, observations, or "I wish it did ..." in the owner's thread - things that clearly do not work properly, as identified in the spec. or user manual to be discussed in this thread. Maybe we even need a specific thread for the class of problems that SD 630 Support is asking for specific data on time, channel, temperature, wind speed, etc. relating to failed recordings or other clear failures. |
