6100 Troubleshooting - Page 3 - Canadian TV, Computing and Home Theatre Forums
Old 2010-03-31, 04:52 PM   #31
pookguy88
Thanks I'll try some of your guys' advice tonight.
You can also try powering down the 6100 overnight, which, IIRC, results in the guide download occurring overnight.
doesn't it have to be powered 'on' to get the guide downloaded?
pookguy88 is offline
Old 2010-03-31, 07:17 PM   #32
Pinza
The problem is the guide now contains hundreds of more channels than Bell was offering when the 6100s came out and the puny little memory in the 6100 used to store the guide is at capacity.
If you were to hide all the channels you do not want to see in the Guide, would that reduce the amount of Data it downloads.?
No, the receiver will get the Guide Data while off.
You can also force a download of the Guide by removing the Smart Card, wait for the System Info Screen to show, then re-insert the Card.
Pinza is online now
Old 2010-03-31, 08:03 PM   #33
Stan Dev
Just to be clear: in this case, "powering down" does not mean removing AC power. It just means using the remote to turn the receiver "off".
Stan Dev is offline
Old 2010-04-01, 11:34 AM   #34
taxtwit
Interesting thought - might try that tonight. To be clear, this is a different procedure from creating a "favourites" list of only those channels you watch on a regular basis - the "favourites" list is just an overlay on the full guide, so you are still updating the full guide with every download.
taxtwit is offline
Old 2010-04-01, 12:50 PM   #35
VuMax
Actually, hiding channels is very similar to creating favorite lists as far as the receiver is concerned. The receiver accepts the guide update package, processes it and then decides what to display(or not) in various categories based on your lock, hide, favourite, etc. selections.
Because communication is one-way, you can not tell the satellite not to send data for specific channels. Nor will the receiver reject or delete data based on locked out or hidden channels. If you lock out or hide a channel and then restore it, you will see that the data is still there.
VuMax is online now
Old 2010-06-01, 10:53 AM   #36
bigmac10ca
Default 6100 Analog Audio Issue
Hi All,
I just installed a 6100 in my home using the Component and RCA Audio outputs from the receiver to my Samsung LCD.
The issue I am having is there is a low buzzing/humming/interference type sound when watching any channels (SD or non SD). The sound is not loud and it is not a huge issue as you can still easily watch tv. I was just wondering if this is a known issue with these receivers and is there an easy fix?
I've tried using both sets of audio outputs on the receiver and tv and even switched the cables around (by putting the red in the white and white in the red in receiver and tv.) And unfortunately using the Digital out will not work for my setup.
Thanks.
bigmac10ca is offline
Old 2010-06-01, 11:15 AM   #37
Blackloz
The only time Ive ever come across that is when I had the audio mixed up and not in the proper slots.
Blackloz is offline
Old 2010-06-01, 06:32 PM   #38
Pinza
That would sound like a bad ground, somewhere.
Pinza is online now
Old 2010-06-02, 10:51 AM   #39
bigmac10ca
Thanks Pinza.
Any tips on how I could troubleshoot that? I'm not too great with electrical, but am willing to give it a shot.
Thanks.
Old 2010-06-02, 11:12 AM   #40
I'm not totally up to speed on these satellite STBs, but if they allow you to control the volume in the STB, then it may be worthwhile setting that volume to "max" and then controlling the volume with the TV. Most remotes can be programmed to control the TV's volume.
With cable STBs one can set the output volume to "fixed" and this provides the highest/best signal to the TV. If the volume is controlled in the STB (via the variable rather than fixed setting), then the S/N ratio is often low, causing hum/audio issues. Just a thought from someone who doesn't know every function available with the particular STB.
57 is offline
Old 2010-06-03, 05:59 PM   #41
Pinza
None of the current or even the last generations of Bell STB's allowed Volume Control via the STB. The last models that I can recall, were the 1000, 2700 and maybe the 4700. These are all very old models now.
I would probably start by making sure they are both in the same hydro outlet, after that I am lost.
Is it possible to borrow another STB to see if it just your that may be faulty.?
Pinza is online now
Old 2010-06-10, 10:40 AM   #42
Rex The King
the 6100 has an optical output, so if you have a home theater device try that connection. The sound is fantastic in that mode.
Rex The King is offline
Old 2010-06-10, 12:50 PM   #43
Pinza
The OP said;
Pinza is online now
Old 2010-06-11, 02:12 PM   #44
Rex The King
Oops missed that. Before I hooked up the digital output, I was not getting very good audio from the receiver to the tv using the conventional hookup.
Old 2010-07-18, 09:01 PM   #45
AdHoc
Question 6100 Troubleshooting
I have a 6100 receiver that's gone wonky on me. First lost all HD channels so I swapped cables at the SW21 and then performed check switch. Got HD channels back but lost regular channels. So thought I had a bad switch so I got a new one but same issues. Checked the signal strength with dish finder and appears good for each dish. Signal strength on receiver is good for whatever dish is coming in. Talked to tech support and they performed resets etc. etc. but still no joy. It seemsed to act up just when the weather was getting warmer. One odd thing though.. when 91 dish is on I can't get all the channels, 400 TSN is not available says error but some SportsNet channels are available.
Not sure what else to do except to line up a service call. Any sugestions?
AdHoc is offline
Tags
6100, bell, receiver, setup
