Ok, so this is probably one of the more stupid questions asked on here, but is there anything you can do when you have two things to connect through HDMI and only one HDMI port on a TV? Is there a such thing as a HDMI splitter or thing that two things can go into at one time or anything?
Pulling it out of the TV every time I want to switch is too much work for the lazy like me. |
Location: Vancouver - OTA, Pioneer KURO Elite Signature PRO-141FD, 27" iMac, WDTV Live.
What you are looking for is an HDMI switch, and they can easily be found.
An HDMI switch or an AV receiver that has at least 2 HDMI inputs (you want the best sound don't you - get some decent speakers to go along with it).
Check monoprice dot com
CAVU 92-inch Infocus Theatre |
And of course, when you get a new A/V receiver, you'll want some nice new speakers and sub-woofer. ;-)
Just about any current gen A/V receiver will have multiple HDMI inputs with an output to feed your HDTV or you can use an HDMI switcher. If going the latter and you're a stickler for PQ than I'd recommend an Oppo HM-31. You can get it in the GTA for a little over $100. Not as cheap as some of the ones on monoprice but it is a very well regarded, quality unit.
Sony KDL-60EX500, Onkyo TX-SR806, Oppo BDP-83, PS3, XBOX 360 w/HD-DVD, Energy Veritas 1.8, AC300 & RVSS, SVS PB13-Ultra |
#7 | |
I found one on eBay for $16...not sure on the quality but the seller's feedback is pretty much comprised of that one item and no negatives.
Is there any decrease in picture quality with a HDMI switch? |
#9 |
Greetings
If it works right, there should be no quality difference ... But if it has issues, you should see it right away ... big glaring issues. regards
Michael @ TLVExperience ISF/THX Video Systems Instructor |
#10 |
Get a switch with remote, not manual switch.
#11 | |
#12 |
Location: VancouverBC/PV Shaw Direct 505-530-630, Telus Landline, Rogers PayGo, Panasonic Viera 50", HTPC-HDMI
I have found a passive HDMI splitter for under $8 and an active splitter for $35. What are the pros/cons of passive vs. active?
I am splitting a home theater output to two TVs, both within 6 feet. |
#13 |
I've had problems with a passive HDMI splitter. An active splitter is typically better.
#14 |
Can you expand on what types of problems? I would have expected an active splitter to be for long runs, i.e. more than 10 feet, or an unbalanced split such as one leg at 20 feet and the other at 6 feet.
#15 |
Like any other passive splitter, there is only so much signal power that must be divided between devices. This means in a perfect 2 way splitter, each device will only receive 1/2 the power. This reduced power may cause problems. |
