ON - Oakville, Burlington, Milton, Halton - OTA - Page 65 - Canadian TV, Computing and Home Theatre Forums
Old 2011-10-06, 06:21 PM   #961
filper
CFTO seems to be very low power.
I can rarely get it anymore.
simplicity is genius...
filper is offline   Quick reply to this message
Old 2011-10-06, 06:40 PM   #962
Jase88
There must be something wrong with your setup--or exceptionally strong local RFI--if you can't get CFTO in Oakville. It's a strong station for me, and I'm in Kitchener.
Jase88 is offline   Quick reply to this message
Old 2011-10-06, 07:48 PM   #963
rob50312
filper CFTO is weak.If your antenna is not directly facing the CN tower you will have trouble.Do you have a VHF antenna ?
CM 4248 at Buffalo,XG43 at Toronto,M4 at Buffalo,CH 11 yagi at Ham.
rob50312 is offline   Quick reply to this message
Old 2011-10-06, 08:08 PM   #964
goforit
From my location cfto is very strong, and that's using 4221HDs aimed at BUF.
91XG (47'), YA-1713 (42'), CPA-19; Denon AVR-1312
goforit is offline   Quick reply to this message
Old 2011-10-07, 10:31 AM   #965
micpoets
I am getting CFTO CityTV and FOX clearly as well as Cool TV in total all 27 channels are coming very nice without any issues.
micpoets is offline   Quick reply to this message
Old 2011-10-07, 05:50 PM   #966
filper
I have a dual CM4221HD array that was professionally installed with a CM drop amp.
You can see the CN Tower and across the lake from my roof.
I am 5' higher than anything me around and the Toronto (lower) antenna is 30' off the ground.
Original scan was 40 channels including a few from Rochester.
It just doesn't make sense.
Old 2011-10-07, 06:13 PM   #967
Jase88
filper, have you done a complete scan with your tuner?! Not just a "add digital channels" partial scan?!?
I've discovered that some tuners will skip scanning a channel, if the tuner had previously detected an analog signal (or another signal) on that channel. This allows the scan to proceed faster, but has the obvious consequence of missing changes (such as those that occur during a digital transition).
From what I understand, your installer does professional work, and it doesn't seem likely that your location or equipment could be the issue. To eliminate the setup, you could do some testing with a cheap set of rabbit ears and a balun. Amplification wouldn't be required, and you should get results even indoors.
Old 2011-10-07, 06:37 PM   #968
filper
I don't think it's anything to do with the installation, and actually I tried the powered Philips antenna I used to use before the professional install to compare results.
CFTO reception is on the light side of marginal. In fact it was the station we have always had the most trouble with.
He's how the array was fine tuned. The front of the house is on the left side, it is due South.
Old 2011-10-07, 07:50 PM   #969
rob50312
Filper I bet if you disconnect antenna facing buffalo ,CFTO would come in.Multipath signals and your tuner cant lock onto a clear signal.Or get a VHF antenna and use a UVJ to combine with your UHF signals from your current antennae.
Old 2011-10-07, 11:57 PM   #970
goforit
For a ganged set-up, the antennas can interfere with each other if too close (e.g., cancel signals)...
Old 2011-10-08, 01:15 AM   #971
Jase88
I think the separation is fine. Probably just an illusion of closeness created by taking a photo from below.
Old 2011-10-08, 11:14 AM   #972
filper
The CM4221HD's are at least 12" apart.
We did a full scan twice on two different TV's for digital only the day of the installation and both antennas were fine tuned for maximum reception. Both sets found 40 digital channels.
Old 2011-10-08, 01:22 PM   #973
filper
Do you think switching from a 4 way drop amp to a 2 way would help ?
There is a 3db difference between the CM3412 and the CM3414.
Old 2011-10-15, 09:07 AM   #974
filper
CFTO 'returned' on Wednesday.
Old 2011-10-15, 11:39 AM   #975
Tom.F.1
Hi filper, I don't think changing amp would help, it only amplifies the signal it gets.
IMHO, Adding a VHF antenna would help, and you might get rf 7 from buffalo.
Tom.F.1 is offline   Quick reply to this message
Tags
antenna, merger, signal
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post replies
OTA Forum Sponsor
