AB - Edmonton, Northern Alberta - OTA - Page 16 - Canadian TV, Computing and Home Theatre Forums
Old 2010-06-05, 08:46 PM   #226
stampeder
Hi aeolus, I've moved your post into the thread covering Edmonton, so scan through it to get an idea of common OTA reception. After that, look through the links in this post: Best Do-It-Yourself OTA Antennas - see these links and also check out the Antenna Chart for the best commercial options.
As you're looking at antennas keep in mind that you need one that is capable of VHF-HI (7-13) and UHF (14-69) in order to get today's digital and analogue stations as well as the digital ones of the future even after the analogue stations are shut down.
stampeder is offline   Quick reply to this message
Old 2010-06-05, 09:45 PM   #227
hkaye
@Aeolus
Bad news is your facing the wrong direction which means the tv signals have to travel thru the apartment walls to get to you. Good news is you are pretty close to the tv towers so you should be able to get reception. How good will it be? That's hard to tell because the signals could bounce off several walls and buildings causing ghosting.
You could try the indoor biquad antenna which can be found in the link stampeder posted. Direct link here, I posted some tips about figuring out what kind of reception you can get in an apartment as well.
http://www.digitalhome.ca/forum/showthread.php?t=124542
It's a UHF antenna but you'll be able to receive 9,11,13 easily (I can with this antenna) because you are close
Anything marked LOS in the tvfool you'll be able to get. The ones 2edge most likely not because they are too far away and you are on the wrong side of the building facing west.
Hope this makes sense.
Best DYI TV antenna plans - I use the Bi-Quad Indoor TV Antenna
hkaye is offline   Quick reply to this message
Old 2010-06-07, 12:19 AM   #228
aeolus
It makes a load of sense. Global's antenna isn't too far from me so I'm not too worried about it. I purchased a DB-2 antenna on ebay for a good price and I'm going to leave my outside window open and mount it in between the back pane and screen. I will likely use a block of wood or two to lift it up just so it doesn't touch any metal. Any gap in the window left from a cable will just get sealed with some foam. I can remove the foam before I move out. I still have another window I can open so that isn't an issue.
However if CFRN gets approval for a VHF-HI signal I won't be able to receive it correct? Perhaps it is time to lobby.
aeolus is offline   Quick reply to this message
Old 2010-06-07, 04:12 AM   #229
downbeat
aeolus: If there's any way you can get your antenna clear of any window screen, then you should try. Screens can play tricks on antennas …
downbeat is offline   Quick reply to this message
Old 2010-06-08, 05:43 PM   #230
j0dest3r
Default CKEM-DT
I was able to pick up the CKEM test feed last night with my Hauppauge stick and laptop hooked up to my Mom's ANT on the roof. The Hauppauge signal meter had an impressive 27 without even properly pointing the ANT. The loop is pretty small, only about 15 minutes or so. I can't wait until this goes live!! Am I allowed to post a picture?
j0dest3r is offline   Quick reply to this message
Old 2010-06-08, 06:42 PM   #231
downbeat
j0dest3r: If you add the photo to one of your albums, you can link the picture in this thread with BB Code.
Full instructions here:
http://www.digitalhome.ca/forum/showthread.php?t=92167
Old 2010-06-16, 12:26 PM   #232
j0dest3r
Thumbs up CKEM-DT Test Loop
OK here is the pic. I can get this signal strenth in Spuce Grove as well as on 23rd Ave Edmonton.
Old 2010-06-16, 12:29 PM   #233
stampeder
j0dest3r is there an indicator in the software as to whether it is in 1080i 16:9 with 5.1 audio?
Old 2010-06-16, 03:19 PM   #234
j0dest3r
No unfortunately, but when I hooked the ANT up to a Samsung HDTV, both 17.1 CKEM-DT and 13.1 CITV-DT are reporting 1080i DD 16:9.
WinTV 7.x might show that information, but I haven't been using WinTV since 7MC seems to do a nice job with a bit of 'tweaking' for Canada.
Old 2010-06-16, 07:41 PM   #235
netdevil
I just checked with VLC and I can confirm that the codec is 1080 (1920x1088, visible 1920x1080), and the audio is 5.1 (a52 codec), plus 4 closed captioning. Here is a screenshot of the codec details:
netdevil is offline   Quick reply to this message
Old 2010-06-17, 12:27 AM   #236
stampeder
Great that's nice to see CKEM coming up in full performance like that.
Old 2010-06-17, 02:59 PM   #237
j0dest3r
CKEM-DT no longer doing test loop woot!~! Their analog feed seems to be down at the moment. It looks fantastic! Global is so soft compared to CKEM.
Oops, my mistake. I didn't get a chance to watch too long, but it looks like they just changed the loop. Real nice HD feed though.
Old 2010-06-28, 08:02 PM   #238
JKR1963
I checked out the test loop on ch 17 a couple of weeks ago. The signal is sure strong with a regular RCA antenna in my bsmt in the west end.
My Panasonic G15 was showing a signal strength of 92%.........I cannot even get the Global over the air on 47 at all
JKR1963 is offline   Quick reply to this message
Old 2010-06-29, 11:26 AM   #239
das75
sure be nice if all the transmitters in one general area, any ideas if Global will be relocating to the SE?
das75 is online now   Quick reply to this message
Old 2010-06-29, 01:43 PM   #240
j0dest3r
See post #221 it has all the info.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post replies
OTA Forum Sponsor
