#16 |
We're about an hour and a half north of Toronto, near the shore of Lake Simcoe. Apparently the Wimax tower (which is quite close -- close enough to see) is pointing to the south, and we're to the north.
#17 |
I'm not sure about the '5 lights' thing. The modem that comes with the Wimax is really just a black box that has one light -- and it's on -- and we go from there to the wireless router and that shows just the connection lights. Things flash of course, but it's not clear when it's getting a stronger signal (and sometimes nothing flashes because not a damn thing is coming in!).
Also, we were told that because Bell and Rogers use the same tower, the problem would be the same (this from the technician who was independent of Bell) since the signal is transmitted to the south. |
#18 |
@crisco: Rogers builds their networks to precise engineering specs. for example, RF amplification can only cascade so far down a line, before a new RF node must be started.
Going closer to your home would likely have necessitated a great expense--which, for three homes, likely wasn't deemed prudent. |
#19 |
@pinza: I wonder if you had a bad modem?
AFAIK, Rogers and Bell do use the same Inukshuk network. |
#20 | |
#21 |
I was using a Bell Wimax outdoor modem that was a neighbors, tried it at my place and nothing. Switched to Rogers, great.
The 2 units look almost identical, large White oblong thingies. |
#22 |
I've been with Bell wimax since 2006 as soon as it was availabe in my area.
Fantastic at first so I thought but coming off dial-up anything was better than waiting for pages to load. For over the past year it's been getting slower and slower from 100 down to 10. After just speaking to Bell I was informed that the tower is overloaded and they will be fixing the problem. There should only be 65 customers on but currantly has 158. And when will this be fixed ? They couldn't tell me. Their solution to my slower speed is to go back to dial-up. Wow what great service. |
#23 | |
I hope my area doesn't get over-subscribed. I don't think many know about Bell's service, to be honest. I see lots of Explortnet antennas in my area (I feel bad for them), but I don't think there is a single Bell outdoor... |
#24 | |
Be sure to check Roger's 3G coverage. It's great in the city (where you have a million other internet options) but is less then Bell's coverage north of Toronto. I tried the Roger's Stick and was only able to get Edge speeds for my area - so I returned it. Rogers is expanding their 3G coverage north of TO and I was told my area "should" have it by the end of June. It's only a tower upgrade - not new towers. If and when it's available I'll try it again.... Cheers |
#25 |
Just checked out ruralconnections.simcoe.ca which is supposed to be bringing high speed to rural Simcoe County. Bad enough that I read that it's using Bell Wimax as its base -- the map on the site shows the projected coverage area, and sure enough there's a big blank right where we live. In other words, they already know that it won't work here, but Bell had no problem selling me the system. We're in the 'shadow' zone so it's unlikely that even putting up a tall tower for the antenna would help.
#26 | |
Also look into this Officially Supported EVDO Data Devices http://www.evdoinfo.com/content/view/2455/64/ The 3GV2 should officially support all EVDO PC cards, ExpressCards and USB modems that have ever worked on the Sprint EVDO network, EXCEPT the Sprint U680 and Franklin CDU550. The list of supported devices provided to us by Linksys includes: •PC Cards (PCMCIA) ◦AC580, S620, PC5740, AC595, S720 and PX500 •ExpressCards (require Novatel XCA-3 pcmcia-to-expresscard adapter) ◦EX720 and 597E •USB Modems ◦U720, AC595U, U727 and Compass 597U but not the U680 (yet) It says U727 and thats what bells using isnt it? Maybe Rob can add some input here? i dont have EVDO. |
#27 |
Much as I appreciate your reply, Gexgeko, I have to admit I don't understand a word of it! Can you translate for a non-techy?
#28 |
U720 USB "stick" is what I use coupled with a Kyocera EVDO wireless router.
Cheers |
#29 |
google "how to internet connection share" Crisco.
Internet Connection Sharing (ICS) enables a Windows computer to share its Internet connection with computers on local area networks. It's been around since Windows 98 SE, and with the launch of Windows XP, it's only gotten better. The wireless EVDO router is the best...how be it expensive.. |
#30 |
| Tags |
| bell, internet, wimax |
