Best Metals for Antennas: Performance, Soldering, Welding, Bending, Working - Page 2 - Canadian TV, Computing and Home Theatre Forums
Old 2009-01-20, 07:07 PM   #16
stampeder
Default DIY Mesh for GH?
It seems to me that if a person is building a Gray Hoverman mesh version with a PVC or other firm frame they should be able to string their own mesh out of wire as needed, right?
Here's the winding chart I'm envisioning (not to scale) that doesn't use any vertical lines. It starts from the bottom left going up and right, then up and left, repeat, lather, rinse, repeat...
Code:
 |------------->--------------|^   (wire holes drilled
^|-------------<--------------|     in frame sides at
 |------------->--------------|^    2 inch centres)
 ^ Start
What would be the best AWG size for the wire, and would copper be the best wire or aluminum or steel for reflector purposes?
stampeder is offline   Quick reply to this message
Old 2009-01-20, 07:18 PM   #17
300ohm
Mclapp did that on one of his bowties by drilling small holes in the side of the pipe. Size wise, what you have handy is dandy, heh. Youll also need some tensioners. But with the reflector gap in the GHs, it makes life more complicated.
That shows the difference between Canada and the US. Somme stuff is hard to get up here.
It may be more local than that. Sounds like more of a demand to fence out some smaller critters up where you are than here. I cant imagine what though.
Still too big an opening for most snakes, heh.
300ohm is offline   Quick reply to this message
Old 2009-01-20, 07:20 PM   #18
stampeder
Default DIY Mesh for GH Using 1 Spool of Wire
If the wire size is flexible enough then the lower left start point could be locked into place (screwed in?) and each weave of the wire through the side holes would really need to be pulled very tight while still keeping the frame from wanting to bend inwards like an hourglass. Hmmm... worth some experimentation but I'm starting to think that store bought mesh would be more rigid due to the vertical wires.
Maybe this DIY design needs vertical wiring too but then linking all the junction points would be a pain! An over-under weave of the vertical wires through the horizontal wires would help, with the whole winding process starting at the lower left as 2" horizontal weaves, changing to 4" vertical weaves at the top left, and ending at the upper right:
Code:
Start at bottom left
      Vertical Down
^ >>>V   >>>>    >>>>    >>>>    >>> END
  _____________________________________
^ ||--V---^---V---^-<-V---^---V---^--||
   START     Outer lines are the Frame, not Wires
It could be done with one spool of wire and only one final cut.
Old 2009-01-20, 08:08 PM   #19
chillonhill
you can get 2 x 3 mesh at reno depot, But I wouldnt know if its any better than your 2 x 2
chillonhill is offline   Quick reply to this message
Old 2009-01-21, 08:26 AM   #20
BongoPJ
Talking DIY mesh
Thanks for the very interesting replies.
I thought about doing some soldering to build my own mesh.
But then, since you mention the gap, what would be the best specs for a reflector grid ? 2x4 or more ? 2x6 ?
About fencing for snakes: maybe there are some outside the island of Montreal so I will take a look at some other stores.
Wiring could be strung in two parts instead of the whole width, using the center post for strength. Question: is tubing better than wire ? Or can wire scatter the waves more ?
Hmmm. Looks like i'm joining the research team... OTA THE way to watch TV
BongoPJ is offline   Quick reply to this message
Old 2009-01-21, 09:03 AM   #21
uglydukwling
TSC sells 2x4 welded mesh as "corn crib wire". I just bought some for a fence project and plan to use the leftovers to build an antenna. The last time I used it, i got it from the Co-op. It comes in 4 x100' rolls, and I don't know if they'll cut it.
uglydukwling is offline   Quick reply to this message
Old 2009-01-21, 09:37 AM   #22
300ohm
The less || vertical wires, the better, for wind load. The == horizontal wires are the important ones for North American TV antenna gain.
Old 2009-01-21, 01:53 PM   #23
BongoPJ
Sorry my question was not clear enough.
After seeing some wire at the hardware store I think it would be easy to use it and build a reflector with a plastic frame; the tension needed to keep the wires straight should not cause any distorsion. And tensioners can be added outside the frame.
The question remains: is 2" the best distance between each wire or should it be more (3") or less (1")? Is it irrelevant since we are mimicking a full sheet?
uglydukwling: What is TSC ?
Old 2009-01-21, 02:34 PM   #24
300ohm
It is mimicking a full sheet, a solid sheet is ideal but any wind would tear down the mast and anything attached, heh. 1 inch distance is about 1 db better on the higher channels, but only about .33 db better on the low channels. 2 inch is a compromise between gain and wind load.
Old 2009-01-21, 02:45 PM   #25
BongoPJ
Thanks 300ohm.
So if I build 2 reflectors with a 2" gap it would be useful to alternate them.
One side being an inch under or over the other.
What do you think ?
Last edited by BongoPJ; 2009-01-21 at 02:46 PM. Reason: Line spacing does not show in diagram
Old 2009-01-21, 07:37 PM   #26
ceeaton
FYI: I tried some 1" x 1" hardware mesh...the pole I had it attached to ended up in the shape of an "r". If the antenna hadn't stopped on the garage roof, it would have been a "p". I quickly rebuilt it with 2" x 3" rabbit wire, and it has withstood 45 mph winds with 1/2" ice attached to it. And we're talking a 6' DBGH. The reception is so much better than when I had it as 3" x 2", I imagine several dBm's (10-15 % signal vs. 35-40%). (With a CM-7000 converter box)
ceeaton is offline   Quick reply to this message
Old 2009-01-21, 08:19 PM   #27
asteroids
So the "ideal" reflector is a solid metal sheet?
Is this true for all SG6 and SG10 family designs?
asteroids is offline   Quick reply to this message
Old 2009-01-21, 09:51 PM   #28
BongoPJ
ceeaton: Thanks for sharing your real life testing. I will definitely keep the 2" spacing.
asteroids: any reflecting surface put behind an antenna will improve the signal. A solid sheet will suffer the full force of gusting wind like ceeaton described. So it is best used inside, for attic installs.
Old 2009-01-22, 02:30 AM   #29
300ohm
Dont misunderstand, you still need the gap for the extra gain, so its not one solid sheet of metal. The mesh reflector models try to approximate a solid sheet with the gap.
The rod reflector models are different. The rods individually resonate and produce unique properties and characteristics.
Old 2009-01-22, 09:05 AM   #30
uglydukwling
TSC is a farm supply chain. In the US, the signs say Tractor Supply Co, but in Canada they just use the initials. They have many stores here in s-w Ontario, but I don't know about the rest of the country.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
OTA Forum Sponsor
